It is currently Sun 24. Nov 2024 4:09:58
PostPosted: Mon 22. Feb 2021 5:15:51
I have 2 Helis set up with telemetry using castle ESC but sometimes it dose not connect to telemetry if I turn power off and on again it will work sometimes but it takes a few tries is this normal . I also tried a third heli but there was now way it would connect to telemetry the only way it would is if I use spirit gov . Using castle gov I can’t get it to connect this heli is with the Spirit v2 and the other Helis are using the spirit pro . What can I do to get the telemetry to connect every time i supply power. I am also using 2.8.0 for all Helis . I love the features it works flawlessly on the Hobbywing ESC s
PostPosted: Mon 22. Feb 2021 14:35:54
please try to set Throttle Frequency to 60Hz.
Is ESC arming normally each time?
PostPosted: Mon 22. Feb 2021 22:32:05
It arms perfectly every time . But my third heli , maybe the CC cable is no good . I will try remove one from another heli and try that . 60hz is where their set up at . Castle live link is enabled .
Users browsing this forum: Bing [Bot], Rbarney and 53 guests
