It is currently Sun 24. Nov 2024 5:30:54
PostPosted: Sun 14. Feb 2021 17:06:55
Hi!
Which of the Spektrum receivers are better for use with u-spirit in an oxy2 sport?
The ar6610t or the spm4651t ?
Do I need any additional cable for Spektrum Integration?
Thanks a lot
Tom
PostPosted: Sun 14. Feb 2021 18:49:49
Both are fine to use. If you go for the spm4651t then you just need to get this.......https://store.spirit-system.com/en/acce ... cable.html
or make one up, pretty easy to do.
then you will be fine :)
Hope this helps
PostPosted: Sun 14. Feb 2021 19:52:09
Thanks!
For the ar6610t will I need the same adapter for the u spirit?
PostPosted: Sun 14. Feb 2021 23:15:45
for the 6610t you only need 1 cable and it's supplied with the spirit.
It's just a male servo to male servo lead.
PostPosted: Mon 15. Feb 2021 5:48:35
I'd consider an SPM4650 - save the weight. You would need to make a cable of course.
PostPosted: Mon 15. Feb 2021 6:29:27
Thanks a lot for all your help!
PostPosted: Mon 15. Feb 2021 15:09:11
Your welcome bud :)
I'd probably go with the spm4651t for the oxy2 like TheSteve said.
Smaller unit and just as capable as the 6610t. Lighter too.
Good luck
Pete
Users browsing this forum: Bing [Bot] and 20 guests
