It is currently Fri 22. Nov 2024 6:52:44
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Sun 31. Jan 2021 9:20:54
ZeXx86 wrote:
OK, now the special firmware is ready for your unit. You should see it in the list. It is enough to flash it and all will be good again. Then the official firmware will work too.
It is called 3.2.2-Fix.
Reinstalling software again will not give me faster downloading.. it is still slow. (in demo mode)
I will try to fix using new firmware. I will get back after downloading :-)
PostPosted: Sun 31. Jan 2021 9:29:03
It seems the slow downloading problem could be related because of too long distance from Korea to us.
We will have to do more testing. At least we know it could happen, but if firmware will download it should not pose a problem at the moment.
PostPosted: Sun 31. Jan 2021 9:36:53
Okay, The heli is alive again now.
I think new firmware supporting menu is a very good feature. I don't have to download the firmware myself.
but, I don't know what part of the internet line is causing this.
So, I would very much like to have the local update feature alive. (safter that way)
- It may be very rare case but I could go offline in the field still need to do something...
I will assist you to find out why it is slow. I can ping your server if you want ...
Thank you :-)
PostPosted: Thu 04. Feb 2021 14:41:20
Hi Guys
I thought I would just let you know I am in the UK and have a fast broadband connection, it takes around 27 seconds to download the firmware?
Kevin
PostPosted: Thu 04. Feb 2021 15:02:45
Omegaman wrote:
Hi Guys
Kevin
better than my case. It took a few minutes for me. And I download 1GB in less than a minute.
So I would say 1) revive local firmware feature 2) store firmwares locally. 3) then fix the speed ^^
Sent from my SM-N986N using Tapatalk
PostPosted: Thu 04. Feb 2021 15:06:43
Thank you for the details. It look like ping is affecting speed a lot, because firmware is verified in each received packet.
It can be fixed for sure. It should take just few miliseconds in almost all cases :)
PostPosted: Fri 05. Feb 2021 9:22:29
If you are interested you can try this version:
https://spirit-system.com/dl/settings/s ... -win32.exe
I hope problem will be resolved and download speed will be much faster.
PostPosted: Fri 05. Feb 2021 10:32:04
Hi Tomas,
I tried this version and the firmware downloads in less than a second.
Kevin
PostPosted: Fri 05. Feb 2021 10:39:51
I can confirm that it is much faster. It takes about 1 second. Well I'm too far from you. :-)
Can't complain any more ^^
Users browsing this forum: No registered users and 45 guests
