It is currently Sun 24. Nov 2024 11:42:01
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Spektrum ar8010t
PostPosted: Fri 22. Jan 2021 21:26:44
It is better to use AR8010T in any case, but not with PWM, but SRXL connection. This is safer and more reliable.
One Spektrum satellite without receiver might be enough, but I recommend 2 satellites. Or AR8010T.
PostPosted: Sat 23. Jan 2021 11:11:58
so it will be safe to run srxl1 on the unit and have full integration?
I'm planning on using all 3 satellite ports on the ar8010t with the newer satellites from spektrum, as i don't want to mix old with new.
Thanks, Pete
PostPosted: Sun 24. Jan 2021 12:13:49
It will be perfectly safe. But with this receiver there is no integration possibility.
It has SRXL v1 which does not support integration.
Please take a look here:
http://manual.spirit-system.com/index.p ... ntegration
You will need receiver such as (if you want integration/telemetry support):
SPM4649T (discontinued), SPM4650, SPM4651, SPM9747, AR6610T
PostPosted: Sun 24. Jan 2021 13:14:02
So when you say integration you mean telemetry? I'm not fussed on telemetry to be honest. So can i use the single cable into srxl for rf purposes only and it work? That is all i want to use it for.
Thanks,
Pete
PostPosted: Sun 24. Jan 2021 13:19:38
No, by integration I mean possibility to configure Spirit unit directly from your radio.
And also telemetry transmission.
But AR8010T is more than enough for flying.
PostPosted: Sun 24. Jan 2021 14:04:16
Right, hopefully my last question on this!!
What is the best way to wire the rx to the spirit 2?
PostPosted: Sun 24. Jan 2021 17:25:50
Scratch that last comment. I'm going to be using the srxl for connecting to the spirit.
I didn't want to just dismiss this rx as it has some good reviews. Plus i didn't fancy dropping another £100+ for new receiver and sat with program cable!. Although it's not the new srxl2 protocol it's still a very good bet in my mind, as having the 2 antennas coming out of the rx and the 3 satellites that will be connected, i think my rf signal will be covered.
All axis's and grey spots will be covered by the sats.
Thanks for all the help :D
