It is currently Mon 25. Nov 2024 0:14:08
PostPosted: Thu 21. Jan 2021 12:50:17
Hi
I can't calibrate the Throttle Curve on the Hobbywing 60 V4 as in the manual discribed.
The Hobbywing should beep several times after plugging in power - but nothing.
I've an linear thottle curve in the jeti ds12 Gas from 0-100% stick is at 100% - Spirit RS bound - but the Hobbywing does not beep.
(Seems that the Spirit RS does not transmit the 100% gas stick position although the diagnostic-page in software shows the right gas stick position)
Any ideas whats wrong ?
Thank,
Matthias
PostPosted: Thu 21. Jan 2021 15:25:42
it was always working for me with several Spirit RS's & different HW's, pls check if:
1. throttle channel (1?) is correctly set in channels setup
2. Spirit gov is deactivated during calibration (!)
3. throttle range is correctly set in Esc/Gov setup
cheers
Michael
PostPosted: Thu 21. Jan 2021 21:50:13
Hi
Problem gelöst :D
Ich hatte den Motor nicht angeschlossen, da ich dachte, dass die Kalibrierung nur zwischen
Sender , Empfänger und Regler stattfindet.
Motor noch mit angeschlossen = jetzt funktioniert es !
PostPosted: Fri 22. Jan 2021 10:11:03
:lol: great it works now for you!
cheers
Michael
