It is currently Mon 25. Nov 2024 6:39:59
PostPosted: Sat 12. Dec 2020 15:45:02
I am retrofitting my Goblin 500 I upgraded to the JIve Pro for the telemetry but the FBL and the ESC are set about 2" too short for the TELME I have it working but its I cant screw down the FBL carbon seat so it wont do. Any way I can order one 3-4" bigger so I can have some play and not worry about it breaking in flight? thanks Charles
PostPosted: Sat 12. Dec 2020 18:10:34
It's only a two core cable, I spliced a section into it to extend. Decent solder joint and you won't have a problem
PostPosted: Mon 14. Dec 2020 11:52:44
It is enough to write the request to order message. Then if possible, we will produce longer cable.
PostPosted: Tue 15. Dec 2020 5:58:02
Thanks I would like a longer cable will do order request I could try the solder solution I just saw your caution on making your own which Im not great at thanks
PostPosted: Tue 12. Jan 2021 3:05:45
So I did lengthen the cable had a dsx2 cable used the wires and soldered extension on but Im not getting Telem Im using telme selection kontronik JIVE pro is 1.14 version and im on 3.21 have a dx-18 which is 1.2 and a Spektrum 4651 RX with the spirit cable SLXR2 cable connected correctly? I saw that I should have a Txt gen option on #2 in telem on DX-18 to do the field integration I don't see that option as I roll thru the choices? Any idea on what I should do the cable was soldered correctly and heat shrinked in middle same end adapters as from Spirit just 3" longer due to positioning of spirit2 and Jive -pro. Any help would be appreciated would love to have integration and Telem options working THX
