It is currently Mon 25. Nov 2024 3:49:28
PostPosted: Sun 10. Jan 2021 13:18:28
I have a problem with TextGen on ix12 with 4651t receiver when used with Spirit 2 fbl, it simply will not work.
I also have a Spirit 2 on another model except it has the 4650t receiver and it connects straight away.
I have a 100% rate switch in order for textgen to operate on both models, works every time with the 4650 but not the 4651.
ix12 has the latest update.
I have tried different firmware on the 4651t with no luck, currently back to latest 2.40 firmware.
Australia
PostPosted: Sun 10. Jan 2021 19:50:59
Did you upgrade your IX12 to the latest version that came out about 2 weeks ago ? Some textgen issues where fixed in that latest version
Envoyé de mon iPhone en utilisant Tapatalk
PostPosted: Sun 10. Jan 2021 22:30:53
Yes as mentioned.
Australia
PostPosted: Sun 10. Jan 2021 23:22:33
Yes as mentioned.
Yep I saw your post but it was broken in the previous version and corrected for me and others in this latest version, I use 6610 and 4651 in SRXL2.
It’s unfortunate if it’s not working for you.
Envoyé de mon iPad en utilisant Tapatalk
PostPosted: Mon 11. Jan 2021 0:14:11
Solved, I reset the model on transmitter and now it’s working as it should.
I had previously used the 4651T with a 6250HX. And despite rebinding, the transmitter was still storing Smart information within the model memory.
Australia
PostPosted: Mon 11. Jan 2021 2:57:17
Yeah !
Users browsing this forum: Bing [Bot] and 27 guests
