It is currently Sun 24. Nov 2024 8:56:09
PostPosted: Thu 31. Dec 2020 23:29:38
Happy new year all!
I'm building my first FBL heli and I couldn't get the throttle endpoints to work - Not sure which part of the drive train is the issue.
Basically, I'm using SpiritRS with 60A HW Platinum V4 going to a Jeti DS12 (Spirit Edition). I have set the us-range in the FBL according to the ESC manual, and calibrated the end points with high/low stick positions. It all sounded fine. But when I try the throttle, I am only getting a spin up at just below half stick. I came from a flybar background, do I still need to adjust the endpoints on the transmitter manually to get the throttle curve right?
Thanks in advance!
Brendan
PostPosted: Fri 01. Jan 2021 9:33:14
maybe you have enabled Governor in the Spirit unit.
Both Governors cant be enabled.
Users browsing this forum: Bing [Bot] and 26 guests
