My name is Timo and i am a Henseleit factory pilot.
I do a nice setup for the light slowfly helicopter TDSF.
Very very happy with the result it fly awesome.
Important: The model is very lightweight and can not handle very agressive settings and high gains. Stay at the soft side all the time. I recommend to stay around 50% +/- 5% Gain and rotation rate around 8-10. A Cyclic Limit is 13 degrees works fine and you stay in the limit every time Tail Gain around 80-100% are fine
Setup: MKS HV9767 Servos at swash MKS HV9780 Servo at tail Henseleit superlight main blades Xblades 96 at tail ( you can use other blades like the MS Rapid 690 only change the cyclic feed forward to 7 )
unfortunatley my TDF is crashed at the moment But i think if you do a basic setup with the wizard it fly good too - You can´t go much wrong with the Spirit.
Users browsing this forum: No registered users and 17 guests
