It is currently Sun 24. Nov 2024 13:49:37
PostPosted: Fri 27. Nov 2020 7:41:44
Hello Tomas,
i had no trouble with Spirit updating on macOS in the past, but it does not work with this release (recent updates on macOS could be very well the culprit too). last time i've tested updating was with 3.2 release... at this time i've done initial update using Windows (under Parallels) as proposed and then tested under macOS and it worked like a charm.
yesterday evening i've tried with 3.2.1 and it did not work under macOS itself, but no problems with recovery under Windows/Parallels. again not possible after recovery using fresh restarted macOS. i've reinstalled (to be sure, you never know what is being installed with the recent macOS updates) the driver as per manual: no success, then the newest drivers directly from SiLabs: no success too.
using Spirit setup tool itself is no problem, but firmware upload does not work. Spirit settings is trying for some seconds to start the upload, then giving an error message asking for restart of settings & unit, but then really is jammed in the system and cannot be restarted unless complete restart of macOS. even then there is never a problem using Windows under Parallels. the unit i've tested with was the last one i received early november (it was already on 3.2 when shipped)
cheers
Michael
PostPosted: Fri 27. Nov 2020 8:22:51
There could be big difference when updating from 3 1 and older. This could cause troubles with a bad USB driver.
When updating from 3.2.0 new flashing process should take effect.
Please use the latest Spirit Settings 3.2.1 for flashing.
PostPosted: Fri 27. Nov 2020 9:39:31
Hi Tomas,
yes, of course Settings 3.2.1 is in use (and all units are on 3.2/3.2.1 before)... on both macOS and Win. i've just done again and documented with screenshots for you.
best regards
Michael
File comment: 2. macOS, 3.2.1 upload failed
File comment: 1. macOS connected, Settings 3.2.1, unit 3.2.1
cheers
Michael
PostPosted: Fri 27. Nov 2020 9:44:07
.... Win success screenshots.
File comment: 4. Win recovery 3.2.1 success
File comment: 3. Win recovery mode
cheers
Michael
PostPosted: Fri 27. Nov 2020 9:45:51
You can try to download the latest USB drivers for Mac.
https://www.silabs.com/documents/public ... Driver.zip
Then after reboot retry.
So the software is waiting after clicking the Flash button? And then after few seconds you can see error, is this correct?
PostPosted: Fri 27. Nov 2020 9:51:20
Hello Tomas,
i've already tried the newest drivers from SiLabs too (see first post)... always the same: fresh boot, install driver, reboot, test, fail :)
yes, exactly: after clicking Flash button the rainbow cursor appears quickly and then it takes some 10-15 seconds until the error message is shown.
nb: just tried with macOS admin user too... just to be sure there is not access rights problem. same result: fail.
cheers
Michael
PostPosted: Fri 27. Nov 2020 10:24:48
Thank you. Are you able to start the Spirit Settings in terminal on Mac?
You have to enter the .app directory and then start the "settings" with ./settings
This should give us error and reason why it is failing. Is this happening with all units?
Here we have Mac with 10.13 and 11.0 and both are flashing well.
PostPosted: Fri 27. Nov 2020 10:38:17
... ok, this is Terminal output (added result from a 2nd unit (v3.2) w/ different programming cable).
File comment: 2nd unit (oldest Spirit 2)
File comment: 1st unit (newest Spirit 2)
cheers
Michael
PostPosted: Tue 01. Dec 2020 5:43:12
FWIW, I have successfully upgraded two Spirit Pro units from 3.2.0 to 3.2.1 using a MacBook Pro on Catalina 10.15.7
PostPosted: Tue 01. Dec 2020 7:32:05
... great info! what exact driver version are you using?
thx
Michael
cheers
Michael
