It is currently Sun 24. Nov 2024 17:50:24
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Thu 26. Nov 2020 18:51:48
You can try to disconnect everything except the satellites.
Please note bind plug at the SYS port and ELE/PIT/AIL is selecting DSM2 and DSMX modulation.
New satellites can work only in DSMX so bind plug must be inserted in the right position.
What radio do you have? Are these original Spektrum satellites?
PostPosted: Thu 26. Nov 2020 19:11:53
Ive been using the DSMX bind plug spot (ele/pit/ail)
These are Admiral (made by Lemon) satellite receivers. Ive used them before in 3 other helicopters (2 of mine, 1 in a friend's heli I setup for him)
PostPosted: Fri 27. Nov 2020 7:25:49
this seems not to be the first report regarding problems with Lemon diversity sats... problems with binding, engine hot starts, failsafe not working correctly have been reported. do you have a genuine Spektrum DSMX sat to test your unit? to be sure if the Spirit is the problem or the Lemon sat?
cheers
Michael
PostPosted: Fri 27. Nov 2020 13:34:00
I don’t, but will buy one or two to try
Users browsing this forum: No registered users and 73 guests
