It is currently Sun 24. Nov 2024 15:53:35
PostPosted: Wed 25. Nov 2020 20:09:12
I have a Spirit which will not enter Bind mode.
I have a proper connection to the software (3.2 on software and firmware), I have started the Wizard and selected 'dsmx,' I have disconnected the usb cable, put a bind plug in ele/pit/ail, and repowered, and the sat will not rapid flash.
Any ideas?
PostPosted: Wed 25. Nov 2020 20:13:58
Binding will not work until Spirit unit will be operating normally. Now it is in recovery mode. Once firmware is flashed properly, binding satellite should work too.
PostPosted: Wed 25. Nov 2020 20:20:50
It's a different Spirit unit, sir. I have multiple.
2 are on helis and work great
1 is in recovery mode currently
1 is being prepped to be put on a heli and is having the BIND issue
PostPosted: Wed 25. Nov 2020 23:00:54
Please help me out
2 units in good working order are unable to bind. Im sure its something I'm doing wrong, but I've tried everything.
sats will not go into bind mode (they do one quick flash and that's it)
PostPosted: Thu 26. Nov 2020 14:26:18
you might try version 3.2.1 that was released right now.
I hope it can help you.
PostPosted: Thu 26. Nov 2020 15:28:52
Thank you VERY much. I’ll give it a try
PostPosted: Thu 26. Nov 2020 16:14:43
It still will not enter bind mode. Satellite gives one quick blink and that's all.
Should I try an older firmware and software which allows binding?
PostPosted: Thu 26. Nov 2020 17:08:16
Oh, this mean that there is no problem with firmware. But very likely your Receiver type is not set to Spektrum DSM2/X.
Only then binding will work.
PostPosted: Thu 26. Nov 2020 18:09:20
Ive selected DSMX under receiver type many times. I've even tried running the wizard to the end and saved the settings first, then tried binding.
I've really tried everything. I've tried different sats, different wire, different usb cable, different power sources.
I've followed the instructions to the letter and I'm running out of ideas here.
PostPosted: Thu 26. Nov 2020 18:16:20
I tried using another receiver and bound the sat to my transmitter that way. It bound, but then when I bring it over to the Spirit, there's no connection.
I just tried resetting both spirits to factory settings and saving the DSMX choice again.
still not working (not entering bind mode)
Users browsing this forum: mainstreet and 52 guests
