It is currently Mon 25. Nov 2024 13:52:06
 Post subject: Which swashplatetype
PostPosted: Sun 15. Nov 2020 22:24:20
I have an jetcat pht3 turbine with 4 servos on swashplate. The problem is that the spirit pro can only H4 90deg i need H4 90deg +45deg.
No it is a hc3sx mounted on the turbine but i would like to fly with the spirit.
So what can i do?
Is it possible to get an update in the future where this will work?
 Post subject: Re: Which swashplatetype
PostPosted: Sun 15. Nov 2020 22:52:47
Hello
what you are looking for is on the EXPERT SETTINGS page.
Cyclic phase:
The value indicates the angle by which the swashplate is virtually rotated. For example a value of 90 will rotate the elevator to aileron. This feature is recommended for models with multi-blade rotor heads. For most other models, we recommend a zero value.
official hacker distributor USA
www.hackermotors.us
PostPosted: Sun 15. Nov 2020 22:58:34
Have try this to change to minus and plus 45 but it will not work
PostPosted: Mon 16. Nov 2020 8:30:16
for sure it can work with Phase angle rotation. We have many scale pilots with similar helicopters.
If not +45° then -45° can work. Then only correct servo reversing is needed.
PostPosted: Mon 16. Nov 2020 15:45:23
okay will try again. Can you say me how i have to plug in the servos then?
Servo ch number on spirit
front left ?
front right ?
rear left ?
rear right ?
that will be great!
Users browsing this forum: No registered users and 14 guests
