It is currently Wed 27. Nov 2024 3:38:07
PostPosted: Sun 15. Nov 2020 19:22:54
I have a Spirit pro and upgraded to version 3.2 from version 3.1
I also upgraded Geo Link to 1.2.0.
When I go to rescue settings and check altitude limit in the windows software although it's enabled I cannot change the min and max altitude.
The text boxes are greyed out..
PostPosted: Sun 15. Nov 2020 19:24:56
Please switch to Bank 0. There is no difference in version 3.2.0.
PostPosted: Mon 16. Nov 2020 11:29:13
Where do I change bank to 0 ?
Thanks...
PostPosted: Mon 16. Nov 2020 11:57:17
At the bottom of the Spirit Settings. If Bank Switching is turned off, then this feature is disabled and you are always in Bank 0.
Other reason that could cause such issue is the window you are viewing is too small. So that not everything can be displayed properly there.
You can try to enlarge the window, some screens are smaller so this problem can occur.
PostPosted: Mon 16. Nov 2020 12:55:28
Thanks, if I increase triggering acceleration does it mean the model needs to decent faster for it to be activated...
So, an example if decrease this setting it will activate rescue when descending slower ?
