It is currently Sat 23. Nov 2024 5:08:58
PostPosted: Sun 25. Oct 2020 17:55:08
Hello, I am building a Nitro 580 with Spartan RS and JETI DS. The sensors I need are the RPM sensor, Tempurature sensor, and battery cell sensor. I have been able to get all 3 sensors working when I use the AUX for power and Signal wire in the EXT/RPM pins but no sensors work on the EXT1.
I am wondering if I can use Sat 1 port for the temp or any other sensor? I'm trying to cut down on wires and avoid Y-cables/expander ports if possible.
PostPosted: Sun 25. Oct 2020 18:18:29
if it is Jeti RPM sensor then it is enough to change port type in the REX-RS settings.
PostPosted: Sun 25. Oct 2020 18:43:17
Is it possible to plug any sensors into Sat 1 port?
PostPosted: Sun 25. Oct 2020 18:46:09
No, SAT port is used only for ESC telemetry.
Users browsing this forum: Bing [Bot] and 2 guests
