It is currently Sun 24. Nov 2024 9:38:38
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Mon 19. Oct 2020 7:38:56
is the Status LED of the GeoLink immediately ON?
GeoLink calibration process will not engage without your request. So if you have already not clicked at the Calibration Request button, this is not the calibration.
So this problem seems to be very different from the previous that is described in this thread.
Can you let me know when the GeoLink was working for you for the last time?
PostPosted: Mon 19. Oct 2020 16:26:04
Blue light is always ON.
The flybarless unit has never flown
Its the second time I plug the Geolink unit. First time was Saturday 17 October, Blue light On and then Off. I was trying to setup the fbl unit with Wifi-Link Module , but Android APP was 3.2.0 and Fbl unit was 3.1.0, so I flash 3.2.0 (with USB interface).
Perhaps if I downgrade to 3.1.0? I have the file ' spirit-fw-3.1.0.4df ' on my computer .
Thanks a lot.
Jorge
Spain.
PostPosted: Tue 20. Oct 2020 7:34:27
ah, this seems to be wrong.
Blue light must always turn off after power up. This mean that GeoLink module is not working properly.
Are you sure you were not flashing GeoLink firmware? Or there wasnt any attempt? It could be enough just to flash it again in recovery mode. Then it should work well again.
PostPosted: Tue 20. Oct 2020 8:30:28
Have you actually tried to open the Geolink page? Fairly sure the 'Not connected' means not receiving a signal from any Sat system?! Are you indoors?
PostPosted: Tue 20. Oct 2020 8:42:44
Not connected is displayed when there is no connection with GeoLink. This is same as when GeoLink cable is disconnected completely.
PostPosted: Tue 20. Oct 2020 17:12:07
Yes, I didn't remenber, after flashing 3.2.0. i tried to update the geolink unit and get stuck at 3%....... :oops:
I have done a recovery (unplug the GeoLink cable and plug it back immediately...) and everything works correctly.
Thanks a lot ! :D :D
Jorge
Spain
PostPosted: Tue 20. Oct 2020 17:17:22
Perfect. So the only problem was GeoLink flashing. I believe all will be OK now.
PostPosted: Tue 20. Oct 2020 20:21:58
Yes, all OK !
Thanks a lot.
Jorge
Spain
