It is currently Mon 14. Apr 2025 14:31:56
 Post subject: rex-rs.bin file
PostPosted: Sat 10. Oct 2020 10:03:17
the Rex-rs.bin file is missing in my Jeti for access to Spirit RS (RX part) ; where can I find that file ?
Thank's.
 Post subject: Re: rex-rs.bin file
PostPosted: Sat 10. Oct 2020 12:34:44
Please download:
https://spirit-system.com/dl/jeti/SPIRIT-3-2.zip
There the required file is included along with the latest version of the integration file.
The content should be extracted and copied to the Devices directory at the SD card.
PostPosted: Sat 10. Oct 2020 18:49:22
had already done this ;-)
to be sure, i've just tried again but rex-rs.bin file still missing.
I've also tried to upgrade my jeti TX to latest version and now, the message has changed for " error : Système non reconnu REX-RS.bin, Line : 1 "
Don't know what to do ?
PostPosted: Sat 10. Oct 2020 19:10:03
Unfortunately this is because required files were copied incorrectly.
It is important that REX-RS.bin file is in the Devices directly, same as Spirit.bin file.
PostPosted: Sat 10. Oct 2020 20:14:55
I Understand but I can’t see the Rex-rs.bin file anywhere....and the file is not in the zip I have downloaded.
PostPosted: Sat 10. Oct 2020 20:19:27
Please redownload the file from our web page. I believe this will fix the problem.
PostPosted: Sat 10. Oct 2020 21:15:51
repeated downloading from your site and uploading to the Jeti TX 10 times......each time the same result, the Rex-RS.bin file is missing.
No problem to access to the Spirit tuning from transmitter but impossible to acces to the receiver part of the Spirit RS.
PostPosted: Sat 10. Oct 2020 21:19:54
Can you find the REX-RS.bin file at least in the recently updated ZIP archive? Please delete the old archives, probably old version is stored in cache of the web browser.
PostPosted: Sat 10. Oct 2020 21:27:50
No the file is definitively not in the archive.
PostPosted: Sat 10. Oct 2020 21:32:03
When I download it, it is there. So unfortunately something is wrong in the computer side. Please remove all downloaded copies first.
Then you could use a different web browser to download it again and all should be OK.
Or you can download it from the attachment here. There the file is for sure contained in the archive.
SPIRIT-3-2.zip [455.52 KiB]
Downloaded 26 times
Users browsing this forum: No registered users and 8 guests
