It is currently Fri 22. Nov 2024 1:17:16
PostPosted: Tue 11. Aug 2020 10:59:30
Hi guys
My name is Timo and i am a Henseleit factory pilot.
I do a nice setup for the light slowfly helicopter TDSF.
Very very happy with the result it fly awesome.
Important:
The model is very lightweight and can not handle very agressive settings and high gains.
Stay at the soft side all the time.
I recommend to stay around 50% +/- 5% Gain and rotation rate around 8-10.
A Cyclic Limit is 13 degrees works fine and you stay in the limit every time
Tail Gain around 80-100% are fine
Setup:
MKS HV9767 Servos at swash
MKS HV9780 Servo at tail
Henseleit superlight main blades
Xblades 96 at tail
( you can use other blades like the MS Rapid 690 only change the cyclic feed forward to 7 )
Happy flying
Timo
File comment: Setup for the TDSF
TDSF-Superlight-Spirit.4ds [255 Bytes]
Downloaded 372 times
PostPosted: Fri 09. Oct 2020 10:39:29
Thanks for sharing your TDSF settings here.
Do you have something similar for TDF?
Guido
PostPosted: Sat 14. Nov 2020 15:31:22
Hi Guido,
unfortunatley my TDF is crashed at the moment :(
But i think if you do a basic setup with the wizard it fly good too - You can´t go much wrong with the Spirit.
Timo
PostPosted: Fri 11. Dec 2020 21:10:46
Thank you, I will start with this setup.
PostPosted: Mon 12. Apr 2021 11:25:59
Hello Timo
My name is Martin Bezděk :D Thank you for your advice :D
Best regards
Martin
Jeti DC-24; Henseleit TDR, Henseleit TDF, Henseleit TDSF, Mikado Logo 600 SX, GM Heli Mi-17, SAB Goblin 630, OXY 5 Meg
Users browsing this forum: No registered users and 17 guests
