It is currently Sun 24. Nov 2024 9:33:56
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Geolink drift
PostPosted: Fri 18. Sep 2020 17:16:24
Nmony wrote:
Tail shaft does not look bent but I will remove and replace.
Replace the bearings also.
PostPosted: Fri 18. Sep 2020 22:04:39
Why?
PostPosted: Thu 24. Sep 2020 12:45:33
New Tail-Blades fitted, does this look better?
I have not replaced the tail shaft yet but i have it if required
PostPosted: Thu 24. Sep 2020 14:41:40
The (big) difference between tail blades on and off suggests to me the blade mounting holes in the hubs are stretched out?
PostPosted: Thu 24. Sep 2020 19:42:59
I'll have a look at that.
PostPosted: Fri 25. Sep 2020 12:29:20
I've checked the Tail Blade grips and the bolt holes look perfect, no elongation.
PostPosted: Fri 25. Sep 2020 14:01:10
@ZeXx86 - any further advice on this please?
Kinda losing faith with this product - I've also been trying to setup telemetry and integration with my DX8, I'm using all the right cables and an SRXL2 receiver with a Castle Talon 90 and I cannot get the motor RPM and sometimes the ESC does not start the motor. I cannot get the integration to work at all, the setup guide on the website does not work.
PostPosted: Fri 25. Sep 2020 16:09:21
Nmony wrote:
Why?
Any play in the bearing can cause your vibration problems.
PostPosted: Fri 25. Sep 2020 16:14:25
I am very sorry for delayed reply.
Vibration level looks good if it is similar with Y axis too.
Unfortunately we are very busy, so it is hard to satisfy everybody.
We can ship you new Spirit unit for comparison.
Please open new thread for your other issue. It is certain we will resolve both.
PostPosted: Fri 25. Sep 2020 22:46:46
Thanks for the reply, I understand you are busy.
How do I go about getting a unit for comparison?
I will post all the axis graphs tomorrow.
Users browsing this forum: Bing [Bot], mainstreet and 54 guests
