It is currently Sat 23. Nov 2024 0:41:29
PostPosted: Sun 06. Sep 2020 17:05:36
Hi!
I have a major issue with the rescue function:
If I activate the rescue(normal) mode while hovering the heli moves up in an angle/sideways instead. I tried it several times.
Since I already read some posts about similar issues I did some tests:
1) I removed the main blades and kept the tail blades mounted. Heli was placed on the carpet.
2) I activated the rescue mode right after initialization. The swashplate moved up straight without any visible angle.
3) I started the motor. ~1900 rpm on main rotor. The vibration analysis displayed no strong vibrations (max. 45% in y-axis, see attachment). Then I stopped the motor.
4) I then activated the rescue mode again. => But then, the swashplate was strongly tilted and never levelled back.
This behavior is always reproducable. Sometimes the swash moves 2 times as it would do during a real rescue action?!, but never straight up as expected.
(Also nothing special in the log file: Sometimes 'Cyclic Ring' messages)
If there is no strong vibration, what could cause the rescue misalignment?
Thank you!
File comment: Vibration analysis with tail blades on
PostPosted: Mon 07. Sep 2020 12:00:56
the angle could be caused by ESC fan.
Can you tell me what Spirit unit and what firmware version do you have?
Can you press CTRL+ALT+M in the Spirit Settings and write the values you see here?
PostPosted: Mon 07. Sep 2020 16:41:46
Hi!
Thank you for the fast response!
I have a Spirit 2 unit on a Logo 500. My ESC does not have a fan: Robbe Roxxy 9100-6
Soft.Ver. is 3.1.0.
I took several values, because the values scatter a bit.
Right after initialization i get:
-12 -10 2050
7 12 2048
While motor is running with tail blades on i get:
-4419 1191 1106
5 591 1058
After stopping the motor i get:
- 2 19 2052
-19 61 2038
PostPosted: Mon 07. Sep 2020 16:54:48
Thank you!
Could you please enable Expert settings / Extended signal processing please?
Then restart the unit and repeat the test with rescue mode.
I hope it will help you.
Can you also let me know how the unit is mounted at the model? Is there something that is touching the unit? For example a free connector/cable.
PostPosted: Mon 07. Sep 2020 18:02:02
Thank you!
No, there is no cable or sth. else touching the unit, I checked it beforehand.
It seems to be better now. I'll try it while hovering tomorrow.
Additionally, I realized that I have stronger vibrations (75% on y-axis) if I attach the battery. For testing it was laying aside.
Maybe I can get the in-flight vibration log working until tomorrow to see how it looks like during flight.
One more thing I realized:
Right after initialization, if I set maximum pitch and activate rescue afterwards, the swashplate tilts to the left.
This would also explain why the heli is rescued in an angle......
PostPosted: Wed 09. Sep 2020 15:29:16
Hello!
I tried rescuing several times yesterday.
What should I say, it worked!
So expert settings did the trick.
(Although I still don't understand the weird swash behavior on the ground)
Again, thank you very much for your help!
Btw., do I have any disadvantages keeping this option set?
