It is currently Sun 24. Nov 2024 12:12:54
PostPosted: Sun 06. Sep 2020 16:14:16
What's the process for calibrating the current sensor telemetry from a Hobbywing Platinum Pro V4 80A and OpenTx 2.3.6 ?
On the OpenTx telem screen, the current (Amps) value changes between 17.xx amps and 23.xx amps. It's jumping around wildly, with no consistent value. It updates every half a second.
My current clamp, attached to the battery, is reading a perfectly steady 21.17 Amps, with the heli on the ground, blades on, spooled up.
So i need to know how to set up the radio so that the values are consistent.
PostPosted: Mon 07. Sep 2020 7:21:09
The best is to calculate depending on consumed capacity. What you will read from the telemetry after flight and then what you will read after charging.
PostPosted: Mon 07. Sep 2020 9:02:10
So there is no need to calibrate the live current reading? I thought that was how the consumed consumption was calculated.
I've going through packs on the ground trying to guess what the current consumption offset should be to get a reasonably consistent value that matches the recharged mAh. At the moment RB1A Offset is set to 5A which gives me a radio calculated consumed of 1000mAh and an actual consumed when recharged of 2100mAh, so this value is still too low, i'll try 10A next. RB1V is correct when a full pack is connected.
> What value are you using for RB1A "offset" in OpenTx?
PostPosted: Wed 16. Sep 2020 12:46:20
There should be no offset configured.
Only I-Motor Shunt value should be changed so that charged/consumed capacity will match.
Users browsing this forum: No registered users and 51 guests
