ZeXx86 wrote:
thank you for the message.
The tail itself will start to rotate once a sufficient vibration level is detected (and also stick movements).
It look like in your case it does not work properly.
So we have made some improvements.
If you wish you can try our testing release:
http://spirit-system.com/dl/fw//spirit-fw-3.1.10.4dfOnce throttle hold is disengaged tail rotor will start to spin at the Low RPM that is configured in the Servos/Subtrim menu - CH4.
I believe everything you mentioned will work properly now.
Good Evening.
Brilliant thank you, this is what I was hoping to see and I will flash and test this firmware tomorrow.
I will go over my settings again following the firmware flash, paying particular attention to the above points to make sure I have it all as required.
I'll report back as soon as I can.
Ian Contessa
