It is currently Sun 24. Nov 2024 10:29:31
[ 5 posts ] |
morrchew
Posted: Wed 02. Sep 2020 18:22:24 |
I have my spirit pro hooked up to a 4949t receiver and every time I disconnect power to the FBL and reapply power the receiver starts flashing again , but here’s the funny thing if I unplug the receiver cable from the FBL which is in the RUD port and plug it back in , the receiver goes sold indicating it’s bound . It happens every time I disconnect power supply from FBL . I have tried the same receiver in a different heli and it works fine . Any ideas as to why it would go into flashing mode when powered up and when the power to receiver is only disconnected and connected back up it Works as it should .
Posted: Wed 02. Sep 2020 18:47:25 |
Are you using Jeti integration cable?
This receiver shouldnt be just in RUD port, this is used only for powering.
morrchew
Posted: Wed 02. Sep 2020 19:07:36 |
The 4649t is hooked up like my other 4 Helis and as per manual . power From RUD and signal from (Ail )port on right side of FBL if pins are at the back
Posted: Wed 02. Sep 2020 21:07:28 |
morrchew
Posted: Wed 02. Sep 2020 22:37:50 |
Solved I had to reflash the boot loader . Everything works as it should thanks for the quick reply .
[ 5 posts ] |
Users browsing this forum: Amatrix and 58 guests |
