It is currently Sun 24. Nov 2024 10:44:26
PostPosted: Thu 27. Aug 2020 1:09:19
Hi all,
I've a problem with a Spirit Pro. A few months ago I was flying my Goblin 770 and all off a sudden during a circuit the helicopter rolled inverted and I couldn't level it. Tbh in the panic I didn't even attempt rescue. I checked all the mechanics of the heli but could find nothing wrong aside from the obvious damage. Canopy, boom, blades, links, belt, shafts, skids and all the usual.
I fixed the heli and was very cautious of flying it again but as I couldn't find anything else wrong I fixed it up and flew it again. After maybe 10 - 15 flights I was flying at our site and half way through a flight the heli rolled 180º and wouldn't roll back. I was over the grass at only 10-20 feet and rather than risk going over the tarmac I went into throttle hold and went into the grass inverted. Again, canopy, blades etc but not nearly as bad due to the low height and early throttle hold.
Because I hadn't any errors in the logs I decided to swap the Spirit Pro from my Goblin 770 and put it on my Tarot 550 Pro that had a Spirit 2 on it. I've flown the Tarot with the Spirit Pro on it now for several weeks and had zero issues in about 10-20 flights again. Tonight I was flying the Tarot when it began to roll inverted. This time I used Rescue which although it was adding pitch as designed it was bringing the heli the right way up again. All I could do was keep flicking the Rescue switch which is spring loaded on my Jeti to keep it the upright while using negative pitch to get it to an altitude where I could attempt to land. I was able to get the heli down to around 10ft and then clicked throttle hold and used the Rescue switch to keep me upright. Thankfully very little damage as it landed on short grass.
Basically I've had the same issue now three times in two machines which have totally different servos, ESCs and motors. The Spirit Pro had/has the latest software installed every time I've had an issue. I can't keep up with the crash costs so I'm hoping someone can point me in the direction I need to take.
Stevie
This is the way the first crash landed.
PostPosted: Thu 27. Aug 2020 7:08:12
that is very sad. Does it mean that Rescue worked properly when engaged?
If so then it rather seems to me like unwanted command from the radio. But if you have more helicopters and it is happening only with this one unit, then this will be rather not the case.
Is connection with receiver over a single wire or PWM?
How long it was flying properly with the unit previously until the problem occured?
Probably the best would be to check the unit to make sure there is everything OK. Can you ship it to us?
PostPosted: Thu 27. Aug 2020 10:13:13
Hi there,
Yes that was the strange part, rescue worked as it should yesterday. Tbh I didn't get an opportunity to try it on the first two crashes. I could have on the second but given the height I was both afraid it was to low already and that if I did end up right side up I'd still not have control but by then be above tarmac with a much worse result. I've been flying the same Spirit Pro in the G770 now since April 19 and only switched it to the Tarot a few weeks ago for testing.
I do fly the radio for planes and occasionally quads as well and never had an issue that wasn't my own fault. Last night immediately after the crash I put two flights on my glider and later another flight on a G500 (although the G500 is on a different fbl). To me this would rule out a radio issue.
Both the Tarot and the G770 run a single wire to a Jeti RSat2.
I'm more than happy to send it back to you for you do investigate - in fact I'd be delighted if you would. What way do you want me to do it?
Steve
PostPosted: Thu 27. Aug 2020 10:31:01
Thank you for the details.
Please ship to this address:
Spirit System
Tomas Jedrzejek
K Olsine 28
73514 Orlova-Lutyne
Czech Republic
You can ship with any carrier. RoyalMail will work well. Only unit is enough to ship. You can add note with your email and request for verification.
PostPosted: Thu 27. Aug 2020 11:23:05
Brilliant, thanks
Users browsing this forum: No registered users and 56 guests
