It is currently Sun 24. Nov 2024 11:41:47
PostPosted: Mon 24. Aug 2020 10:00:58
Hi
A couple of questions abaout this esc,i plan to use the governor in spirit unit the white cable from cc goes to the
pit pin in unit ok.But the manual says connect a resistor 10Kohm betwen the white and the red cable for use
telemetry?Else use the telem cc cable?I can only se brown red orange on this cable and a shrinktube in the middle.
I cant understand this?
Can anybody explain?
//Latjo
PostPosted: Mon 24. Aug 2020 10:17:06
red and orange wires are same as white and red.
Pit cable is for rpm sensing for governor. It is 4th wire. And also there is secondary bec cable.
Anyway we highly recommend to get telem cc cable.
PostPosted: Mon 24. Aug 2020 10:47:55
Ok
I order a telem cc cable,whth that the white cable connects direct to the pit pin(for rpm)and the throttle cable
connects to telem cc cable and the telem cc csble goes to Trottle on spirit rs unit?
am i correct?
//Latjo
PostPosted: Mon 24. Aug 2020 10:58:33
hi
The telem cc cable is on backorder?
//Latjo
PostPosted: Mon 24. Aug 2020 12:26:53
Yes, you are correct. Yes, cable is not in stock, but we will produce them within 1-3 days.
PostPosted: Mon 24. Aug 2020 14:42:03
HI
Is it then ok to put the 10Kohm resistor between the red and orange cable?
//Latjo
PostPosted: Mon 24. Aug 2020 14:42:53
Yes, this is OK if done properly.
PostPosted: Mon 24. Aug 2020 14:58:17
OK
Thank you Thomas
PostPosted: Fri 04. Sep 2020 7:25:31
Hi
The esc is up and running,difficult to get it to arm,find a video on web.
Governor working ok and telemetry displays all data as it should.
//Latjo
