It is currently Sun 24. Nov 2024 10:16:56
PostPosted: Tue 18. Aug 2020 11:38:25
Just checking to be sure that I am going in the right direction. I am using a Hobby wing rpm sensor which I am powering at 3.3volts from the sat port. The sensor output is being connected to the pit terminal of the ele/pit,ail port. I am using the multi adapter to connect 2 sats, the single wire of the multi adapter connects to the ail pin of the same port.
Can they work together?
PostPosted: Tue 18. Aug 2020 13:10:18
yes, looks good.
PostPosted: Tue 18. Aug 2020 14:33:50
Thank you, Tomas.
Users browsing this forum: No registered users and 23 guests
