It is currently Sun 24. Nov 2024 10:58:04
PostPosted: Tue 18. Aug 2020 8:11:11
I have som problems arming my Yge esc. after several tries i connected de esc directly in rx throttle channel, and esc is arming.
I did check throttle range in general, governer tab, governer is off in al banks. And it all did work before.
After connecting a servo in throttle (aux) channel from spirit the servo is just buzzing in one position, the corresponding channel on rx is working well, servo rotates analog to throttle curve.
Could there be a problem with the spirit? all functions are working exept throttle. I have more sprits working, no problems at all.
Verstuurd vanaf mijn SM-A520F met Tapatalk
PostPosted: Tue 18. Aug 2020 8:18:54
please make sure that Throttle function is assigned for the correct channel. It should be Channel 1.
Default settings have this function unassigned in the most cases.
PostPosted: Tue 18. Aug 2020 8:29:17
Yes i checked, the heli has flown lasg week, the only thing i changed is the esc..
and governer settings, (governer off)
is it possible to try complete reset en reload al settings from computer? I never did. but saved all banks to the pc now.
PostPosted: Tue 18. Aug 2020 9:11:58
You can load the settings simply by clicking Load in the Backup tab.
But I am afraid this will not help, if the settings are same.
Is Throttle moving in the Diagnostic tab normally?
Servo at AUX must move according your Throttle Curve.
If this will not move then also ESC will not work.
PostPosted: Tue 18. Aug 2020 11:17:15
In diagnostic tab the throttle signal is moving. And it worked before I didn't change anything exept turn off governer.
The servo is not working(only buzzing) in spirit throttle port, in corr rx port ch 1 its working
Before i have flown with castle esc without problems, switching to yge because active freewheelen, but troubles with arming esc started then. Esc works fine on rx throttle port
I hope it is a setup problem but now pulling my hair out.
PostPosted: Tue 18. Aug 2020 11:48:43
I did a complete reset of the spirit, loaded the backup en voila.. servo was moving on throttle port (aux) I thought problem solved...but.. After connecting esc... esc didnt arm.. and after connecting servo on aux port ... no moving only buzzing..
When i connect esc on rx directly the esc does arm..
PostPosted: Tue 18. Aug 2020 12:28:50
Very likely something is still configured wrong.
Probably you have enabled Castle telemetry in the ESC Telemetry. With this option other ESC can't work.
PostPosted: Tue 18. Aug 2020 13:08:07
Your right, i realised it before i read your post! I set telemetry on disabled, recalibrated the endpoints of the esc and got the right beepings.
Tnx for helping!!
Users browsing this forum: No registered users and 57 guests
