It is currently Sun 24. Nov 2024 10:48:24
[ 4 posts ] |
latjo-k
Posted: Sun 16. Aug 2020 12:04:30 |
Hi A question, on G420 the links from servohorns to swashplate are fixt lengdt,and they are to short so when servo horns are at middle the antirotationsarms pointing down,and i get more negative pitch, and how should i level the swashplate?Anyone know how to deal whith this issue? //Latjo
Posted: Mon 17. Aug 2020 7:14:31 |
you should make all servo push rods longer. This will increase collective pitch so that it can be at 0°.
FrankFuss
Posted: Mon 17. Aug 2020 14:34:20 |
The servo links are fixed length, but the links from the swashplate to the main blade grips are adjustable for zero pitch. You tweak the Spirit Subtrim (tuning) parameters to level the swashplate.
latjo-k
Posted: Mon 17. Aug 2020 16:34:08 |
Hi Yes i have done it that way,but the geometry is not perfect either the servoarm arent at 90deg or the radius arms. i planing to rise the 3 servosupport abaout 1mm then the geometry should be perfect. //Latjo
[ 4 posts ] |
Users browsing this forum: No registered users and 55 guests |
