It is currently Sun 24. Nov 2024 10:54:20
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Sun 16. Aug 2020 15:48:36
hello
trying to find a good tail gain on trex 600 with spirit 2
but even at 100% gyro gain
i get a 90° tail jump ( tail to right ) on any pitch pump :(
tail servo is savox sb-2272mg
PostPosted: Sun 16. Aug 2020 16:24:56
you can try to increase Gyro Common Gain. This will multiply normal gain.
PostPosted: Sun 16. Aug 2020 16:37:01
What rudder servo do you have? If it is a fast servo what value do you have for Rudder Delay? Default of 5 is not ideal for fast servos.
PostPosted: Sun 16. Aug 2020 17:25:09
rudder servo is savox sb-2272mg
and common gain is already at 1.20
rudder delay is at 0 or 1
PostPosted: Sun 16. Aug 2020 18:19:53
It is also very likely your mechanics is not working properly. If you can see such bad behavior then it is almost certain.
Alternatively your servo arm length is wrong. What are values of the end-point limits?
PostPosted: Sun 16. Aug 2020 19:05:35
mechanic was hard but that has been fixed
rudder limits are 145 - 155
btw, raising the common gain to 1.40
and configuring gain on tx at around 90-95
finally led me to some oscillation
but only in idle2 at 2300 rpm
and tail is still not so precise :(
btw thanks to all for the help ;)
PostPosted: Sun 16. Aug 2020 19:10:21
Hmmm, so at 2300 you still have tail blowout or do you have another symptom?
PostPosted: Sun 16. Aug 2020 19:25:12
at 2300 little tail blowout at less than 90%
at 95% tail oscillation
PostPosted: Mon 17. Aug 2020 9:12:11
If running the governor, the gain could be too high or too low for response gain.
Your tail thrust bearings could be worn out.
The tail servo could be going bad.
How much collective pitch are you running?
What is piro consistency set to? I would start off around 155 and only turn up main tail gain as much as possible first. If it's already low or default then check the things above.
PostPosted: Mon 17. Aug 2020 9:19:23
For this model piro consisteny should be around 170. Not more than 180.
Yes, governor could play a big role too.
Users browsing this forum: Bing [Bot] and 54 guests
