It is currently Sun 24. Nov 2024 13:35:58
 Post subject: logviewer.lua
PostPosted: Thu 30. Jul 2020 11:30:38
How can i change to the current flight, there is always the previous flight
 Post subject: Re: logviewer.lua
PostPosted: Fri 31. Jul 2020 9:33:36
You have to access the log again, then it will be from current flight. Probably something bad is happening each flight, for this reason you can see saved log from previous flight.
PostPosted: Sat 01. Aug 2020 12:51:44
no it was always the same previous log because it was always 490s long.
I have tried it to read it with the computer
spirit-log-2020-08-01-133415.pdf [71.11 KiB]
Downloaded 33 times
now it is cleared and i see the current flight
Thanks a lot
Downloaded 19 times
PostPosted: Sun 02. Aug 2020 7:13:10
Oh, you have to read/load it completely in your radio.
Only then it will be erased.
PostPosted: Tue 04. Aug 2020 13:28:24
Thanks for the tip i will try it next time
