It is currently Sat 23. Nov 2024 15:31:13
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: New DFC Swashplate
PostPosted: Sat 18. Jul 2020 10:36:48
ZeXx86 wrote:
Here you can find step by step guide how to make these steps perfectly precisely and correctly:
http://manual.spirit-system.com/index.p ... d_Geometry
Can you take a photo of your model? I have not seen swashplate with not adjustable push rod.
Please note I am talking about things like this (attachment).
Those are definitely adjustable, I was talking about the elevator arm, that is not a pushrod.
I will follow the link you provided here.
I was doing the swash plate leveling in the software, should I only do it by adjusting the length of the pushrods instead?
Yesterday is history, Today is a present, Tomorrow... a dream.
PostPosted: Sat 18. Jul 2020 12:39:30
arms of the swashplate shouldn't be adjusted in any way. At least with swashplate you linked.
PostPosted: Sat 18. Jul 2020 13:32:58
I followed the link to the manual you provided
1) it keeps talking about 3 servo rods, what 3 rods do I have?
2) in item 6, it says to adjust the rods to get swashplate level, until now, didn't touch the rods, just used the sub trim in the software.
So, I am not clear. To get the swashplate level at stick in the middle, do I use the software or change the rods?
PostPosted: Sat 18. Jul 2020 13:36:48
The three linkages that connect the swashplate to your servos. Do you have a video chat service? I would be happy to video chat to better help
PostPosted: Sat 18. Jul 2020 15:17:13
You have to set rods. With software you should just set servo arms to be in the middle.
PostPosted: Sat 18. Jul 2020 23:16:26
Would like that if you can, where in the world are you located? There will be a time gap between us, so we have to make an appointment.
I have Skype, Zoom and Lifesize for video chats
Looking forward to hear from you
Alex
PostPosted: Sat 18. Jul 2020 23:20:08
Do you mean:
1) Level the swash plate with mechanical changes of the servo pushrods? OR
2) Set close to 90° by moving the servo arms, then level the swashplate with the software?
Please try to be more explicit
PostPosted: Sat 18. Jul 2020 23:22:48
The swash plate DOES NOT have any adjustable arms, do you mean the push rods from the servo to the swashplate SHOULD NOT be adjusted?
PostPosted: Sun 19. Jul 2020 2:33:31
Yes, the linkages, not the swashplate itself.
Do you have a skype?
PostPosted: Sun 19. Jul 2020 2:56:48
Please view this for proper swash setup.
https://www.dropbox.com/s/bna6a781v35q210/600setup?dl=0
Also; did your gartt 600 DFC head come as a set with a new main shaft as well? Because the DFC head requires a lower mainshaft than the stock main shaft. Part: h60247t
Users browsing this forum: Bing [Bot], mainstreet and 25 guests
