HeliMLM wrote:
... just follow the initial 3 step checklist i posted here...
OK Michael, here is what I did:
1) On my Tx I set AUX3 to Switch A and assigned to it CH8 in my channel assignment. It is OFF in the down position and ON when I flick it up.
2) In Spirit, I elected "Coaxial" in the Stabi Tab - see image
3) Followed and checked the action OFF / ON - see images
Does this all LOOK OK to you? If so, it means that when Switch A is down - I fly by myself( IF I can) or up - Coaxial.
Now, to another question which is critical to my setup. I DO NOT manage to get to 6 degrees in Step 8 of the wizard. The closest I can get is 8 degrees, when the box gets to 64 and DOES NOT go any further, why?
Does it mean that my swashplate / pitch center is too high on the shaft, or what?
Thanks again
Alex
