It is currently Sat 23. Nov 2024 17:32:15
 Post subject: Tail gyro HH
PostPosted: Fri 10. Jul 2020 5:22:08
How do I set the HH in Sprit Pro?
I did all the wizard steps already
Yesterday is history, Today is a present, Tomorrow... a dream.
 Post subject: Re: Tail gyro HH
PostPosted: Fri 10. Jul 2020 8:58:52
if TX gyro gain is -100 to +100
from -100 to 0 is normal tail
from 0 to +100 is hh tail
if TX gyro gain is 0 to 100
from 0 to 50 is normal tail
from 51 to 100 is hh tail
PostPosted: Fri 10. Jul 2020 13:29:59
Oh, I see - I know that.
I thought there is a way to set that in Spirit
Cheers
PostPosted: Sun 15. Nov 2020 15:13:33
I must have miss read the instructions, I understood this to be for the head gain. I too am trying to find how to setup the tail or being to adjust it alone and not the head at the same time. I am switching from Axon and you have two channels for gyro 1 head and 2 tail. Is this not the same ?
PostPosted: Sun 15. Nov 2020 18:06:26
No it is not the same.
Gyro Gain (for tail) is by default assigned at Channel 5. Just like the most other gyros.
Cyclic Gain is configured in the unit, default settings will work almost in all cases. So no need to change it from default usually.
But eventually you can assign the Cyclic Gain for a dedicated channel too.
But Gyro Gain is always only for Tail controlled by a single channel. Never two things mixed in one channel. This would not work too well.
