It is currently Sun 24. Nov 2024 13:58:53
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Posting problems
PostPosted: Mon 06. Jul 2020 8:26:17
when you have some attached files
the button has to be there
if not, you are doin something wrong in the attachment process
maybe go give a look to attachment management in your user control panel
PostPosted: Mon 06. Jul 2020 9:14:46
HI
maybe you have reached the total quota of attached files.In that case you have delet som in your
user control panel.
//Latjo
PostPosted: Mon 06. Jul 2020 10:16:16
It is enough to click at three buttons in total.
First select file, then add the file as attachment and then confirm the post.
Anyway if there is some problem you have to see some error. Otherwise you just missing to click at the buttons.
PostPosted: Mon 06. Jul 2020 10:41:50
Hello all, Yes - I was doing something WRONG... Will see if I figured it out
I added step-2 of the wizard. My elevator connector is at the front, but when I pick the model to Trex-600, it shows the swashplate with CH-2 at the back, why?
I reset the unnit to factory, I have NO reversing on the Tx, I have no reversing on the unit.
All my stick directions are correct, including the tail / rudder.
The only thing I can't get is the 6 degrees, I can get as close as 8.2 degrees. Does this indicate that my swashplate is sitting too high?
Yesterday is history, Today is a present, Tomorrow... a dream.
PostPosted: Tue 14. Jul 2020 9:29:19
I think you need to explicitly subscribe to the topic to get emails. It doesn't auto subscribe from the topics you created (I wish it would).
And of course check your spam folder..
PostPosted: Tue 14. Jul 2020 13:15:39
it does :)
just go in your "user control panel" -> Edit posting defaults
and enable: Notify me upon replies by default
PostPosted: Tue 14. Jul 2020 16:58:41
urgno wrote:
it does :)
That's good to know, I have the right settings now :)
PostPosted: Tue 14. Jul 2020 22:20:44
glad to help ;)
