It is currently Sat 23. Nov 2024 12:28:50
PostPosted: Thu 02. Jul 2020 4:59:18
In the relevant part of the manual in section 3 it says:
3 Throttle output
In case you have just SRXL2 satellite receiver set up Throttle Output from the unit at (AUX/AUX1 port). Please assign Throttle channel in the General/Channels at Channel 1.
For Full-size receivers it is optional, because you can connect Throttle/ESC directly to the receiver at port 1.
OK, so this is my case, but CH1 is intended to connect the PITCH Servo, so where should it go instead?
I am still unable to set the Spirit correctly....
Yesterday is history, Today is a present, Tomorrow... a dream.
PostPosted: Thu 02. Jul 2020 7:19:44
CH1 is output port for servo.
Channel 1 is input channel from your radio.
These two are completely unrelated and different things.
As stated in the manual, Throttle Output is always AUX1 port. You only have to assign Throttle Function to input Channel 1 of the radio.
PostPosted: Thu 02. Jul 2020 8:10:35
Ok, I understand and watched again video part 2.
The problem remains
When I moved the ailerons stick (right stick in mode 1) it activates the elevator.
When i move the elevator stick up and down, it activates the aileron.
What should I do?
I don't manage to get past this step 5 of the setup
PostPosted: Thu 02. Jul 2020 9:39:50
Can you confirm that all channels are moving properly in Step 5?
Please take a look at the screenshot in the attachment. Is this identical with yours?
You can even disconnect all servos because they are not important until Step 5 is working properly.
PostPosted: Thu 02. Jul 2020 10:15:16
All channels are now moving properly in Step-5
I tried several times to add pictures to me response, but for some reason I DO NOT manage. The page accepts my upload but it actually doesn't show my pictures, why?
THe channel assignment I had to make to get to all channels moving properly, based on your creen shot image , in my case it is : 1,3,2,4,5,6,7
I had to swap 2/3 because the sticks were performing the opposite function, not clear why???
I will try now again to upload my image, but I hope you can understand my setup and help me with my latest questions above
Thank you
PostPosted: Thu 02. Jul 2020 10:20:07
You have to select image for upload and then click Attach file.
And then send the post.
If Aileron bar is moving while moving with Aileron stick and Elevator bar is moving while moving with Elevator stick then all is OK.
So then you can continue to another step. No changes in the mapping, channel reverses should be performed in your radio from that moment.
PostPosted: Fri 03. Jul 2020 9:46:28
I selected an image, there is NO such option Attach, there is Add the file, and I do that, but the file is NOT showing.
I managed to get through all the steps and have the following problems:
1) On the general Page - what is Flight style? I am NEW in helicopters and at this point need to learn to hover. So, should I select a small number, or a high number?
2) The unit status light is flashing, not solid - what does it mean?
3) When I need to set pitch to 6 degrees, the best I get is 7.3 on both blades. Does it mean that my swash plate is too low? Do I need to adjust the push rods (My head is a DFC head)
Thank you
PostPosted: Fri 03. Jul 2020 10:09:20
Thank you
1) Flight style.....Lower number, 2 or 3. The higher the number the 'snappier' the heli becomes.
2) With the USB dongle attached the unit will slowly pulse the light.
3) You need to move the slider to get EXACTLY 6* (Only use one blade to set all the angles. Mark it and the Grips as the Master blade.)
Users browsing this forum: No registered users and 45 guests
