It is currently Sat 23. Nov 2024 0:20:17
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 Post subject: Spirit Pro setup
PostPosted: Tue 30. Jun 2020 10:47:27
I started my setup today, but the sticks move the wrong controls, here are my Details:
Tx - Spektrum DX9 Black. All servos are at 100/100, no reverse
My Rx is a Spektrum serial Satellite SPM4651T, so I selected
Horizontal (0), 120 Swash , SRLX2 .
My servos connections are:
CH1 – Pitch
CH2 – Elevator servo
CH3 – Aileron
CH4 – Rudder servo
AUX1 - ESC (Red wire removed)
AUX2 - BEC
The setup cable plugged into the SYS Ch.
The connector cable from the Rx is connected to RUD / ELE as per manual for this type of Rx
Not clear what should Throttle channel assigned to, the same about Gain, Bank
What am I doing wrong?
Yesterday is history, Today is a present, Tomorrow... a dream.
 Post subject: Re: Spirit Pro setup
PostPosted: Tue 30. Jun 2020 12:04:33
Should simply be the Channel asignment in your Tx is different to what Spirit is expecting. The Channel sub page will help you get it correct.
Your Servo connections look correct. Are you running an external BEC? Only ask as you have removed the red (power) wire.
PostPosted: Tue 30. Jun 2020 12:40:12
You first need to check in the Diagnostic page if the channels move correctly if so then the TX mapping is correct. If not you reassign channel mapping and servo reverse in the TX. You then you move to the Servo page and reverse any channels that are moving servos in the wrong direction.
PostPosted: Tue 30. Jun 2020 13:41:00
Yes, have a separate battery for BEC.
Will check channels on th TV, didn't think about it.
PostPosted: Tue 30. Jun 2020 13:43:18
sorry, not clear. I am new to all this
Thank you
PostPosted: Tue 30. Jun 2020 21:27:44
Step 5 of the Wizards (diagnostics) has you check the channels and stick movements to verify FBL is seeing correct stick direction.
PostPosted: Tue 30. Jun 2020 23:35:28
OK. I didn't look there.
If anything is wrong, do I fix it on the Spirit or on my Tx?
PostPosted: Wed 01. Jul 2020 0:02:24
If any control is backwards in Step 5 you correct it in the TX.
Then in step 6 you correct form servo movement in the software only.
PostPosted: Wed 01. Jul 2020 5:18:10
I tried changing channel assignment in my Tx, so that Throttle is set to AUX1, but the Tx doesn't give that option.
Any suggestions?
It is a Spektrum DX9 Black.
PostPosted: Wed 01. Jul 2020 11:35:48
please do not look at the swashplate. First make sure that channels in the Diagnostic tab - Spirit Settings are moving properly.
You should not change channel assigment in the unit - default layout should work always.
Only make sure that Diagnostic tab are showing a proper values, especially if channel directions are OK.
It does not matter which TX Mode do you have.
Users browsing this forum: No registered users and 56 guests
