It is currently Sun 24. Nov 2024 16:04:13
PostPosted: Mon 22. Jun 2020 19:27:24
I just received my Spirit RS and started configuring it. I own a DS-16 (1) with the newest FW installed, and use a Mezon 130 RPM , newest FW on that one aswell.
Problems are:
1.) i can see the Spirit RS in the device manager, but as soon as i enter the settings it gets deactivated with an „x“
2.) i can see the Rex RX as well, but cannot even enter the settings, i get an error message.
3.) i do not get any telemtric infos from my mezon, refreshing did not help
I can see the Rex when using the internal Jeti Box, and i can enter the configuration and measurement part.
But usually i can see the mezon in the Jetibox aswell, here it is shown, but without possibility to enter.
What did i do wrong ?
Thx
Boris
PostPosted: Mon 22. Jun 2020 19:48:52
very likely you are using E2 pin, which is not correct. This pin shouldnt be used.
Please try to disconnect everything that is not needed, then try again.
PostPosted: Mon 22. Jun 2020 20:01:08
Ok, i did that. The red plug from Mezon (containing the telemetric signal wire ) is now in Port E1.
I can access the Spirit in device manager. Thanks !
But my other problems still exist.
Cannot access the REX RS in device manager. Error "configuration can not be loaded" is beeing shown
Cannot get any telemtric inputs from the Mezon
Cannot see the Mezon propperly in the internal Jeti Box
PostPosted: Mon 22. Jun 2020 20:19:09
At the E1 port or EXT pin.
See Spirit RS guide.
http://manual.spirit-system.com/index.p ... _Telemetry
PostPosted: Mon 22. Jun 2020 20:21:00
You have to proceed according manual.
Important is to download the latest Spirit Integration files that include REX-RS.bin file amongs other.
Extract the archive and copy the content at the sdcard of your radio.
It is described in the linked guide.
PostPosted: Mon 22. Jun 2020 20:40:08
For the Mezon issue, likely you will need to set port E1 as EXBUS. By default it is configured as JetiBox/Sensor.
This should be done in the REX-RS interface.
PostPosted: Mon 22. Jun 2020 21:01:38
Yes, thank you very much.
I originally did download them, but I thought just because i could see the them in my DS16 SD Card that they were allready fine. But your are right of course, they needed to be updated.
Now i can access the REX-RS, and i get those telemtric data from the Mezon too.
Top !
Thread can be closed, all my problems solved within a glance :-)
PostPosted: Mon 22. Jun 2020 21:44:34
You are welcome :)
PostPosted: Tue 23. Jun 2020 13:28:49
just one more remark concerning your answer:
No, it does not work with setting as EXBUS, i have to use JetiBox/Sensor
Users browsing this forum: No registered users and 50 guests
