It is currently Sun 24. Nov 2024 15:48:34
PostPosted: Sat 20. Jun 2020 11:28:08
Hi Tomas
I have a minor issue with my Geolink on my Heli. I recently wanted to have a look at the recorded GPS data to see if I pass a road with my flight range and have to be carefully cause some people walk along this road. I then recognized that the latest recorded data files are over one year old. The flights in the meantime have all not been recorded or at least are not listed in the drop-down. I was in hope that the newest updates probably will solve the problem but I had no luck. Do you have any advice how I can solve this? The functionalities of the geolink as also of the SpiritPro are with no problem (except of a message that often says that also flight log data has not been stored completely, don't know if that has a connection to this).
Thanks in advance.
PostPosted: Sat 20. Jun 2020 12:14:29
Geo Logs do not replace old ones as new ones are logged. When the logs are full you wont see any new ones added. Just delete the log files and then you should start seeing them again for the next flight.
PostPosted: Thu 25. Jun 2020 20:33:37
Thanks I was not aware of that...ok, in my opinion it would make more sense to cycle the logs. But now that I know that I have to clean the log buffer if I want to have a new one I can also handle with that.
Users browsing this forum: mainstreet and 44 guests
