It is currently Fri 22. Nov 2024 7:27:10
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Jeti it is!
PostPosted: Fri 05. Jun 2020 3:01:27
Did I miss it before or is there a price now? 13 553,00 Kč Or around $575
PostPosted: Sun 07. Jun 2020 21:33:17
So... Availability date for the DS-12 Spirit edition to the US?
PostPosted: Mon 08. Jun 2020 17:21:40
It depends how easy certification will be.
But I believe all will go well. Probably 3 weeks.
PostPosted: Mon 08. Jun 2020 18:15:37
My new Spirit/Jeti radio is on order. Looking forward to the radio and the spirit RS here in the USA. It should be available just in time for me to start flying this year after a few medical procedures.
PostPosted: Tue 09. Jun 2020 11:33:31
I did not see the new Jeti Spirit radio go on order and it show backorder again or did you order somewhere else?
PostPosted: Tue 09. Jun 2020 15:02:03
You can order through the Spirit Eshop even though it says back order.
Just hit the back order button and it will add it to your order.
PostPosted: Tue 09. Jun 2020 18:35:09
That did not work for me before for some reason but it sure does now! Thanks. Placing my order
PostPosted: Wed 17. Jun 2020 13:11:01
This might be good enough to make me switch from Open TX running on an X10. There are a couple of things that are not clear to me, because of the way Jeti have purchaseable options in the firmware which enable some of the hardware features. So I would like to know if the Spirit version has all three transmitter modules enabled, i.e. two at 2,4Ghz and one at 900Mhz. Normally to get those with the standard DS12 costs significantly extra.
PostPosted: Wed 17. Jun 2020 13:14:14
900 Mhz is not enabled by default, because there is not even 900 Mhz receiver yet. But in very near future it will be available and can be also connected as a backup receiver for Spirit RS.
PostPosted: Wed 17. Jun 2020 13:27:43
OK thanks, that makes sense. What about the two separate 2.4G transmitters, are they both enabled?
