It is currently Sun 24. Nov 2024 15:52:14
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed 17. Jun 2020 9:04:20
Could you please do this:
Set General/Position to Horizontal (0°)
Then perform calibration with CTRL+ALT+U again.
Set General/Position back to your original position.
Then check if the problem is solved (possibly after restart). If no, I will send you PM with other solution.
PostPosted: Wed 17. Jun 2020 9:16:42
Sorry can’t send 4ds file as the computer I use for spirit setups is not online
Bear with me I’m trying to find a way to get the file to you
PostPosted: Wed 17. Jun 2020 9:44:16
Re calibration at horizontal (0Deg) made no difference,
I am using an iPad Online just now , I assume there is no software got iPad ?
PostPosted: Wed 17. Jun 2020 10:17:39
Ah, please check your PM.
App for iPad is integrated in the Wifi-Link.
PostPosted: Wed 17. Jun 2020 11:06:07
Thanks to ZeXx86 All sorted , again thanks to everyone who contributed
Kind regards Kenny d
PostPosted: Wed 17. Jun 2020 11:07:18
You are welcome!
The issue was resolved by resetting calibration data to factory defaults.
PostPosted: Fri 19. Jun 2020 15:43:26
and how is this done ? ;)
PostPosted: Fri 19. Jun 2020 18:47:40
With key shortcut, but it is not public, because people would try it without real need to do this.
PostPosted: Sat 20. Jun 2020 1:29:26
true ;)
PostPosted: Sat 20. Jun 2020 14:09:12
If updating from 2.x to 3.x, is the -U calibration required?
Users browsing this forum: mainstreet and 46 guests
