It is currently Sun 24. Nov 2024 14:44:38
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue 16. Jun 2020 22:05:28
I have just updated 2 helis from 2.1 to the latest 3.1 I think , on the bench pressing recovery the swash now goes down instead of up & then After 2 seconds the elevator servo dives down and states there , I have managed to get the swash to go up in recovery but it still tilts forward & remains there , , I have 8 spirit units , my 2 Uspirits On oxy 2’s updated ok I think from 2.8/3.0 , so 2 not working & 4 more to still update , all help appreciated
PostPosted: Tue 16. Jun 2020 23:37:25
I had a similar type of problem after upgrading one of my helis to 3.1.0. I then reflashed the firmware and that corrected the problem. Please try reflashing the firmware and letting us know the result. Thanks.
PostPosted: Wed 17. Jun 2020 6:48:27
Thanks frankfuss, I have downloaded 3.1.0 several times so have have flashed each of them with the same problem on 2 Separate units , I have then changed them back to 2.0.0 / 2.2.0 / 2.6.0 and with them flashed it Is no longer Connecting to the radio but does bind if I go back to 3.1.0 , I also upgraded the software to 3.1.0 when I added 3.1.0 firmware to my computer
PostPosted: Wed 17. Jun 2020 7:20:02
maybe you did performed accelerometer calibration with 3.0.0 version. Could that be case?
Please press CTRL+ALT+M when Spirit unit is labels upwards - as close as possible to the horizontal position.
Also please let me know also from which unit it is.
This will let us know if calibration is not OK. It can be corrected easily then.
PostPosted: Wed 17. Jun 2020 7:51:13
Hey, I used CTRL-ALT-M on some helis on v3 due to rescue/swash issues. Now I've gone back to v2.8. If I go to v3.1 will this also cause issues? Sounds like doing the calibration again will fix it, is that correct?
Cheers
PostPosted: Wed 17. Jun 2020 7:55:59
Thanks for the reply , it’s a standard red spirit serial no 55-34-a8-ef-57-2
I have never flashed 3.0.0 into unit , I have done the Ctrl- alt- m process
PostPosted: Wed 17. Jun 2020 7:57:31
If you performed calibration with 3.0.0 then doing calibration again with 3.1.0 might be necessary.
Calibration is performed with CTRL+ALT+U - at the time of pressing the keys Spirit unit should be perfectly level.
For anybody that have no issue it is not recommended.
With CTRL+ALT+M you can easily check if calibration is really good or no.
All pilots that were not performing own calibration will very likely never need it since it is done in Factory.
But at least you can anytime check it, because previous firmwares were not using this sensor part.
PostPosted: Wed 17. Jun 2020 7:59:32
Kennyd: Can you tell me what values you can see there? The -M shortcut will not fix the issue, but will tell us if the issue is due to calibration.
PostPosted: Wed 17. Jun 2020 8:00:51
Oh, ok, thanks, I forget which I did now, was probably -U, which fixed the rescue/swash issues. What's the difference between the functions of -M and -U ?
Thanks.
PostPosted: Wed 17. Jun 2020 8:02:53
Accelerometer data - 219 - 142 - 1984
Users browsing this forum: mainstreet and 53 guests
