It is currently Sun 24. Nov 2024 15:00:00
PostPosted: Fri 12. Jun 2020 16:00:27
I swapped my spirit pro for a spirit 2 on my Goblin Drake, I'm using the telemetry as I did on the pro but the spirit 2 has 1 less port so I can no longer use my opti-guard.
Is there a work around so I can use my opti-guard even though all other ports are used up?
PostPosted: Fri 12. Jun 2020 16:17:20
You can use a Y-cable to have the opti-guard and one of the servos or the receiver share a port on the Spirit 2.
https://store.spirit-system.com/en/acce ... cable.html
I wouldn't connect the opti-guard to the receiver instead of the Spirit. It should provide power directly to the Spirit.
PostPosted: Fri 12. Jun 2020 16:21:02
I used a servo Y cable connected at AUX1 (or I believe any port except SYS or ELE/PIT/AIL). Then the BEC (or supply) connects to the Y as well as the Optiguard. The Y connector is double-sided-taped to the outside frame to be accessible, then when bench testing I unplug the Optiguard and connect a separate 2S battery, to prevent having a main (12s) battery connected. I get mine from Tomas @ Spirit (German made), the Y cable needs to be good quality.
Cheers, Andy
PS Frank beat me to it - what he said!
PostPosted: Sat 13. Jun 2020 9:52:27
Thanks all for the responses I'll go with the y cable on the bec.
PostPosted: Sat 13. Jun 2020 11:29:52
It's critical the opti guard provides power to BOTH rx and spirit, otherwise its pointless. The FrSky integration cable (needed because I'm using telemetry) doesn't carry power so I've got a cable running from the rx to the Spirit (with the data pin removed)
I'm going to try and document it later today.
PostPosted: Sat 13. Jun 2020 12:34:29
Thanks, I don't use and Rx just the telemetry unit and a dsmx sat.
Users browsing this forum: No registered users and 50 guests
