ZeXx86 wrote:
could you start the motor with blades off and observe swashplate behavior?
If you will see nothing it is more likely it is still electrostatic issue, because model is grounded.
In some cases grounding cable might not help unfortunately.
Do you remember when the issue started to appear?
I was flying version 2.7.0 and had a crash (mid Feb., my fault) Changed main rotor holder from plastic to metal, changed tail boom. Flew
satisfactorily (no evil) a couple of battery with the "new" parts (end Feb) . Then COVID19 (the real evil) interrupted any flying activity.
As I flew again it started showing the odd behaviour. In my memory I saw it happen even on the ground while spooling up before takeoff (trying to bank with no input).After that I found also GeoLink negative altitude readings, so I updated to latest versions of S/W and F/W.
I will take the blades off so to confirm what happens on the ground.
