It is currently Fri 22. Nov 2024 23:48:17
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: srxl2 AR6610T
PostPosted: Fri 29. May 2020 12:13:30
Any news on this release Tomas ?
PostPosted: Fri 29. May 2020 13:38:45
Is already out since yesterday or so. Check the download page for v3.1.0 here:
http://spirit-system.com/download.php
PostPosted: Fri 29. May 2020 16:20:59
This is how I have to set up to get the stick inputs to respond although aileron does not show reversal in spirit software but does work on the Heli,
On spirit, is this ok ?
Red in sys
Esc in aux1
Brown/red to rud and orange to pit
On ar6610
Jeti cable to port 1
Aile to port 2
Ele port 3
Pitch to port6
Ar6610 latest firmware and spirit and setup software up to date
PostPosted: Fri 29. May 2020 16:40:20
Well got to the servo trim setup page and the spirits blue light goes out, go back to diagnostics and it comes back on so obviously that approach does not work
PostPosted: Fri 29. May 2020 16:56:02
Why have you got your servo's plugged into the receiver? They should be plugged into the Spirit....
PostPosted: Fri 29. May 2020 17:56:43
Nothing happens they don’t respond to stick movements on the servos or in the wizard
PostPosted: Fri 29. May 2020 18:18:08
1st,make sure you have updated 6610t to latest FW, then in spirit/ wizzard make sure you have receiver set to SRXL2 then follow the wizzard instructions and all will be ok...
PostPosted: Sat 30. May 2020 19:33:15
Finally sorted and ready to maiden, one question where should I plug the single yellow Rpm signal wire from the hw platinum esc Into in the spirit ? I have the term uni cable from the esc into sat1 on the spirit and geolink into sat 2
PostPosted: Sat 30. May 2020 20:02:22
So finally installed the 3.1.0 Firmware into Spirit Pro.
Spektrum AR637T receiver works now with Spirit Pro in SRXL2 mode!!! I had to put the Jeti Integration cable into Channel 1 (Throttle) on receiver and re-route the Throttle output to other free channel (CH5 - Gear in my case). I control my ESC direct from receiver.
Few tests with Jeti cable on AR637T side:
- Bind/Prg/SRXL2 - port works NOT !!!
- CH1 (Throttle) works in SRXL2
- small 4pin JST SRXL2 on top of AR637T works the same way too in SRXL2
PostPosted: Sat 30. May 2020 20:07:34
@Neilsteers the RPM, yellow wire, goes to the middle pin on the elevator/Pitch/Aileron connector
Users browsing this forum: Bing [Bot] and 48 guests
