It is currently Fri 22. Nov 2024 23:16:48
Post new topic Reply to topic  [ 112 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: srxl2 AR6610T
PostPosted: Mon 11. May 2020 6:13:37
Matt finally answered: empty channel data should still be sent before RF is connected. See here for his reply.
chris
PostPosted: Mon 25. May 2020 1:38:44
So I'm using the Spektrum AR637T receiver, which got almost the same hardware as AR6610T, but it got also gyro.
The connection per SRXL2 does not work (the Bind/Prg/SRXL2 port). Only the PWM method.
I will try tomorrow to use the CH1 for SRXL2 on AR637T. Maybe the SRXL2 will work... :)
PostPosted: Tue 26. May 2020 7:24:32
SRXL2 is fully supported from version 3.X.
This week we will be releasing new update. So it is necessary to use this version.
PostPosted: Tue 26. May 2020 9:11:15
... this is really great news. thx a lot Tomas!
the fix of the failsafe problem with 4651T/Spirit together with the update of the 4651T firmware that should arrive in the next days (fix of RSSI problem on some EU Tx and some other topic) there should be no more problems in fully using SRXL2 hopefully :)
cheers
Michael
PostPosted: Tue 26. May 2020 12:16:06
Thank you Thomas.
We all are looking forward for new Firmware v3.
I wish to you and all of us to have minimum "baby" ilnesses / errors.
It should be a big leap forward for Spirit.
Max
PostPosted: Thu 28. May 2020 8:22:27
Could someone send me a breakdown of the channels assigned in the spirit setup along with any reversed channels, I have the 6610t and having same issues, have updated firmware on the receiver and spirit2 unit and have all the cables plugged in as per this thread but still can’t servos to respond in the correct way
Many thanks
PostPosted: Thu 28. May 2020 9:54:13
... the new firmware (3.1) with complete support of SRXL2 is in the preparation of being released - better wait for it :)
cheers
Michael
PostPosted: Thu 28. May 2020 10:29:49
Thanks Michael
PostPosted: Thu 28. May 2020 10:36:01
We will be releasing tomorrow.
PostPosted: Thu 28. May 2020 12:49:26
Thanks tomas
Users browsing this forum: Bing [Bot] and 54 guests
