It is currently Sun 24. Nov 2024 16:48:21
[ 4 posts ] |
MaxSupercars
Posted: Sun 24. May 2020 13:54:36 |
I'm using Spektrum iX12 transmitter and Spektrum AR637T receiver connected to Spirit Pro in PWM mode. All cables are connected upon instructions, so I use Jeti cable for AIL/PIT/ELE + 2 cables for RUD and AUX1.
In Spirit settings I have chosen 120° swash plate and PWM mode. When I move the sticks in iX12 all indicators in Diagnostic TabPage are moving right, but the real swashplate on the helicopter is moving not right. If I move the elevator stick, the whole swashplate moves up/down (acts like collective). If I move the collective stick on iX12, the swashplate tilts forward or backward (acts like elevator).
What do I bad?
Thanx!
Attachments: |
yufasa
Posted: Sun 24. May 2020 14:31:01 |
There is a whole setup you need to go through. When you run the wizard you: 1) set up you connection - in your case PWM, the orientation of your spirit and the swash 2) configure the travel and direction of your stick - this is also the “Diagnostic” page when not in wizard mode 3) set up your servo direction - here is is more important to configure the movement of the swash and tail when moving the heli before you touch the control sticks! Once you have the directions fixed by selecting the appropriate check boxes for each servo and/or the pitch you can now go into your radio and reverse the direction of the servo output if the sticks are still moving the swash in the wrong direction. 4) set 0 pitch/ set limits/max travel/6 degree reference etc. 5) setup up any bank defaults you would like and you are done....
I am making a video of this but I am waiting on the re-release of 3.0 before it will be out.
Keep asking away as there are people here that will help
FrankFuss
Posted: Sun 24. May 2020 18:12:22 |
You have at least one servo where the direction needs to be reversed. See "Servo Reverse" on the "Servos" screen. Check reverse for the servo(s) that are moving in the wrong direction. If you follow the Wizard exactly you will have success, that is, you should read everything.
MaxSupercars
Posted: Sun 24. May 2020 18:21:09 |
Guys, thanx for help. You were right. I reversed 2 servos for front CH1 and CH3 and now it works properly!
Thank you!
Max
[ 4 posts ] |
Users browsing this forum: No registered users and 31 guests |
