It is currently Sun 24. Nov 2024 18:01:53
PostPosted: Sat 23. May 2020 20:22:36
Looking for help, have the 6210t connected to the spirit by JETI cable red and brown rudder and orange to pit, esc to aux1 , if I connect servos to rx they respond but connected to the spirit 2 they don’t and in both scenarios the bars do no move in the channel screen in the spirit wizard, what am I doing wrong ?
PostPosted: Sat 23. May 2020 22:21:57
I assume you mean the 6610t?. Have you set receiver type to SRXL2 in the Spirit in the general tab, then in rx....
PostPosted: Sun 24. May 2020 0:25:36
Hi
Yes the 6610t, and yes set to srxl2
PostPosted: Sun 24. May 2020 8:29:58
Neilsteers wrote:
.....and orange to pit...?
if you have really connected to PIT (middle pin) this is the problem... check wiring with Spirit manual: should be the topmost pin iirc.
cheers
Michael
PostPosted: Sun 24. May 2020 9:58:09
Hi Michael no the orange wire is in the top pin
PostPosted: Sun 24. May 2020 10:17:14
Ok... would have been an easy one :)
and the firmware on 6610T is updated and Spirit is using actual firmware?
cheers
Michael
PostPosted: Sun 24. May 2020 10:31:36
HI follow this thread.
viewtopic.php?f=20&t=3791
PostPosted: Sun 24. May 2020 14:43:45
I have updated the rx but not the spirit software, software on wizard is showing latest release 2.8
Users browsing this forum: No registered users and 87 guests
