It is currently Sun 24. Nov 2024 11:40:06
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
PostPosted: Tue 12. May 2020 17:09:26
Serenus wrote:
What receiver configuration you have chosen in OpenTX? Did you take the one with telemetry? Can you send a screenshot?
And channels 1 to 8 with telemetry in the radio.
Sent from my Redmi Note 7 using Tapatalk
PostPosted: Wed 13. May 2020 5:46:23
I am using the RX-8 recv and Spirit 2. Short history, I upgraded my flybarless spirit gen1 to spirit 2 on my Goblin 570.
OpenTX Integration was working with original spirit, since upgrading to spirit 2, exact same setup as before openTX integration is not working anymore. Will wait to firmware 3 comes out, most likely will be fixed then.
PostPosted: Wed 13. May 2020 7:00:24
I am using OpenTx 2.3.7 and on my spirit pro the 2.8 version and telemetry and integration is working with my R-XSR receiver.
Which versions you are using? Perhaps your versions are not working together.
PostPosted: Wed 13. May 2020 7:56:09
Glad it's not just me that is running into this issue. I have all the latest firmware installed on my radio, and have tried a few receivers now in Access and D16 mode, and I still cannot get any data back to the radio..
Serenus... May I have a picture of how you have you little reciver wired up.. I have one on my Oxy 4, and directly soldered onto the sbus pad so I didn't have to use the inverter cable, but I haven't figured out how to wire it for telemetry?
PostPosted: Fri 18. Sep 2020 21:46:34
Have you fixed your issue? Sorry I have not read you post. I am not using the Pad. I am using the connector and the integration cable. Parhaps the integration cable is not doing the same as the pad on the R-XSR is doing.
Users browsing this forum: No registered users and 37 guests
