It is currently Sun 24. Nov 2024 17:32:19
PostPosted: Thu 07. May 2020 19:41:06
So I just received a Spirit Red and downloaded Spirit-setting 2.8.
When I connect the FBL I get a message informing me that there is a version mismatch and I need to fix it...the Spirit unit has 3.0 on it!
The problem is that I cannot find spirit-setting 3.0 as apparently this is required to downgrade the firmware.
I tried to use the "recover mode" and it will not show my any firmware files so I guess the 2.8 software does not like something with higher firmware?
I tried to find a copy but been unsuccessful so far.
Note that configuration is disabled so I can do nothing with my new FBL until I match the app with the firmware.
PostPosted: Thu 07. May 2020 20:32:51
if you downloaded Spirit Settings 2.8 recently you can downgrade Spirit firmware directly without any issue.
Just select 4df firmware file at the Update tab and press the Flash button.
PostPosted: Fri 08. May 2020 11:42:30
Thank you I got it sorted out and everything is working as far as I can tell. If everything goes well I will try flying this weekend....
Users browsing this forum: Bing [Bot], mainstreet and 73 guests
