It is currently Sun 24. Nov 2024 17:35:07
 Post subject: Problem with Geolink
PostPosted: Fri 01. May 2020 14:52:34
I have mount for test a Spirit Pro with Geolink on a Trex500xt.
Spirit is in firmware 3.0.0 and Geolink is in firmware 1.1.0
Radio Futaba T18MZ, Receiver Futaba 7008SB Fasttest, connected in Sbus to the Spirit.
Channel 1 Throttle unassigned (Connected directly to the receiver).
Channel 2 Aileron - Channel 3 Elevator - Channel 4 Rudder - Channel 5 Gyro Gain.
Channel 6 Pitch - Channel 7 Bank - Channel 8 Stabi
I only use Bank 0 and I configure Stabi to Coaxial Mode. That's work.
The problem is when i try to activate a function of Geolink ...
I specify that the Geolink is calibrated and it display where i am in MAP View.
BUT when i try to activate one of the function : Postion Hold, Altitude Hold or Return to Home
via a switch on the Channel 9 ... nothing happens ...
And worse if I release this switch Channel 9, I'm not coming back to Stabi mode !
If anyone can advise me ... thank you
 Post subject: Re: Problem with Geolink
PostPosted: Fri 01. May 2020 18:14:45
Spirit falsch konfiguriert.Den wenn du Schalter aktivierst,muss im Geo die Aktivierung oder Schalterstellung sichtbar sein.
Gruß Jürgen
PostPosted: Sat 02. May 2020 13:31:47
No the Geolink is correctly configured.
In Diagnostic, switch channel 8 => stabilisation coaxial active and switch channel 9 => Geolink active (Pos Hold)
When I active Pos Hold nothing happen and then when I deactivate Pos Hold => Stabilisation coaxial is out !!!
So what can I try to solve this problem ?
PostPosted: Mon 04. May 2020 22:10:54
are you trying these features at home?
I recommend to try anywhere outside.
Also you can check if you can see GeoLink feature engaged at the Diagnostic tab (nothing else should be engaged).
PostPosted: Tue 05. May 2020 8:51:55
Hello Zex,
You tell me (nothing else should be engaged)
I suppose when one geolink feature is engaged !
It's OK ?
So stabi mode + geolink does not work together ?
And if it's true, i have to deactivate first stabi mode before activate a geolink feature ?
Thank you to clarify
Users browsing this forum: Google [Bot], mainstreet and 72 guests
